Have decided to replace the tries on my F3L. I want to use Vredestein Quatrac 5 tires. For the front tire I see they have a 175/65/15 or 165/55/15. For the rear, 215/65/15, or 205/55/15. :thumbup: Tom :spyder:
Printable View
I am running the 175/55R15's on my F3s. Great tire that I purchased from tire rack.
I am running 175 up front and the 205 in the rear. I did a lot of research and it seemed that was the best combo. They all fit fine, no issues. They also run smooth. I have to tell you, the rear looks narrow and the tread pattern isn’t as good looking as the Yokohama’s... had to let you know. I
believe I am still the only one on this forum running all 3 Vredestein Quatrac 5. The Sportrac 5 is actually rated better on wet surfaces.... harder to find though!
Thank you all for the help. :thumbup: Tom :spyder:
Well, now what? No 205/55-15! They have a 205/65/15. What did you guys that have Vredestein on your bike use? Tom :thumbup::spyder:
Vredestein 205 width claim to be 8.5” as opposed to 8.1” like the average 205 width.Remember every manufacturer uses a different method as there is no real concrete standard!!
Yokohama 205 have a similar claim... bottom line these 205 widths should be just slightly narrower than the 225 width Kenda. I did a ton of research and the outcome is only as good as the info I am receiving!
