Fog light bulb change
Right side is easy, remove cover, remove wires, turn bulb, remove, insert new bulb, hook up wiring, replace cover, done.
Left side not so easy. Remove mirror, side cover, inspection cover, and loosen the front side cover so that it will slightly slip over the fog light, one screw and 3 plastic studs. Loosen the gear clamp on the intake tube and take the intake tube off of the air cleaner housing. Now you can move the intake tube out far enough to get at the fog light cover easy enough to make the change. Probably best to have another set of hands to hold the intake out, helpful but can be done on your own.
Which model did you do this on?
This is what I went through on my 15 rtss. It took 1.5 hours to figure the left fog light out and 20 minutes to replace right side and the two head lights.
