short reach bars for f3--what if i try them and dont like them ....
since the dealer no longer uses the sample ufit model how does one know if the short reach bars (17 F3t) will actually be enough of a fix to warrant switching out from the standard factory bars. Im sure somone's gone through this before. In this regard should i refrain from adding farkles onto my bars (cup holder, phone holder etc) until im positive that i wont be better off with the short reach bars. Help please. I am getting fatigued and i think the short reach bars but will be better but its kinda a crazy hunch to have to invest in and not know that it was a worthwhile modification/cost/time investment etc.
sounds great--glad it working for you--
i really appreciate your input
Quote:
Originally Posted by
bboley
They measure 2 1/2" longer, that doesn't sound like much but it worked for me. There is an aligning slot in the bar that goes over a pin in the mounting block assembly. With the slot there is a lot of up and down range so that you can find the perfect spot for you and tighten it up. Mine ended up a little higher than the middle of the travel range, that helped keep me from hunching over to reach the bars. The controls are slightly rotated from the stock position but it only took a couple of days before I was use to it. All in all it was a great choice for me. :clap:
