Rear rotor bolts are TIGHT !!
OK .. getting ready to install a new rear tire on my F3S. Gonna remove the rotor just in case my local guy needs it off. Get out my 3/8" drive Craftsmen ratchet and 13mm socket. Heat up the bolts a bit to loosen the locktite. No way! Get out my 16" breaker bar and ... crap! Did I just strip out the bolt head?? Pheewww. Nope. I just split the socket!! Nuts to that. Took the wheel down to my co-worker at the hardware store. 13mm impact socket and impact driver made quick work. Damn BRP and their yellow stuff. Probably TQ'd to a crap ton of ft/lb's too.
