Originally Posted by
finless
27 is too low. It should be like 90 as I recall. (search here and youi can find what the prssure should be as I am not 100% sure).
The compressor is not running with the key off is it? It should only run when the engine is running.
So you either have a messed up position sensor, leaking bladder or hoses.
You can manually put air in the bag via the shrader and see if it holds air (without turning the bike on). If it does then it's not a leak problem but another issue like with the position sensor.
Bob
