Looking to buy a 2018 F3T does it have self cancelling turn signals. Can't find the info in specs. Thanks
Printable View
It does. If you make a fairly sharp turn, it will cancel right away. If you only make a sweeping turn, it will self cancel after 30 seconds.
Pg, 23-24 of the operator's guide.
I figured out sometime ago for both parts and manuals documents you must go to the top page and then drill down to the desired year and model and language. http://www.operatorsguides.brp.com. Links direct to the documents or parts pages don't work, but usually they take you to the top page. I don't know why this one doesn't.
Mac is correct. I thought I might be able to get exactly to the '18 F3 there but it didn't work.
Have to turn handlebars at least 30 degrees to activate.......
If you push in on the centered turn signal switch (not moving it left or right) it will cancel the turn signal. As has been said, a sharper turn will auto cancel the turn signal, but a sweeping turn will not. The above method is also useful when changing lanes as you don't want to look like the "India Delta 10 Tango" ryding with your turn signal on for no reason for 30 seconds...
John
