AWESOME combo: Shock Relocator--Swaybar--Elka shocks
Some of you who have ridden with me know that I like speed and I like curves and I really like them together. My latest mod is making that type of riding a lot of fun!
Some history...I started off on a stock 2011 RS-S with its fairly soft shocks. I was really happy last year when I rode a 2012 RSS with Fox Racing Shocks, which made such a difference over the previous model. Really loved those shocks.
This year when I went back to the 2011, I knew I couldn't go back to that soft ride and I added BajaRon's sway bar. I thought I would love it, but honestly couldn't tell how much difference it made because I was back to a downgraded set of shocks. :banghead: My recent riding had been on a Spyder with stock swaybar, but with Fox Shocks and I just couldn't discern a huge difference now that I had the old 2011 stock shocks but an improved swaybar.
So at Spyderfest when John put on my Elka shocks, I was quite the happy camper. NOW I could really tell the benefit that Bajaron's swaybar gave me since my shocks were similar to what I had gotten used to on the 2012. Ask Harvey - it was a FUN ride home after Spyderfest.:doorag:
I really thought I was done. But this weekend Rickylen added his Shock Relocator kit and HOLY COW!! It's like I won a trifecta!nojoke
The Spyder was rock solid at 80+ mph on the highway with lots of buffeting from trucks and the occasional strong gust from threatening thunderstorms. Then I hit some nice curves heading to Eureka Springs and rarely braked into a turn. Spyder handled like a charm and stayed nice and flat except in some <ahem> extreme acceleration moments as I tried to wake up Nanny.
On my way home today I was blessed with some fairly light traffic on a part of Hwy 65 that has lots of nice tight uphill curves with the double passing lane so helpful for scooting past campers and trailers. So I scooted and my new triple threat setup meant I could take those uphill curves at just about whatever speed I felt like throwing at it.
My takeaway? Anyone on a 2011 or earlier RS or GS who likes to ride with some passion owes it to themselves to make 3 changes: (if you have a 2012, just stick with #2 and 3)
1. upgrade your shocks - Elkas, Fox or even shocks for the RT
2. get BajaRon's Swaybar
3. get Rickylen's Shock Relocator Kit
One more thing, I found myself riding one-handed a lot today, just giving my left arm a rest. Normally I don't do that much except on straightaways, but today I was just much more confident in the handling on curves. Still was safety conscious but I didn't need to grab both bars as much. It was a good day. :dg2:
Agree 100% Faran! My RT-S is a completely different beast with these three changes. I also have car tires up front and they change things for the better too, although at this point you may not notice the improvement as it is slight.
I haven't dove into the suspension yet, as I've been focusing on engine/fuel/intake upgrades. I'm finished now, and Elkas look interesting.
Agree but with some important caveats...
Your post is much appreciated and anyone following your recommendations will almost assuredly enjoy better handling performance from their Spyder. However I'd just like to point out one perpetuating misconception that might be interpreted from your recommendations. For strictly reducing body roll in the corners high performance shocks are not vital. If your primary goal is to reduce body roll in the corners you need only add the improved anti-sway bar and (optionally) a greater spring preload. Yes, high performance shocks certainly do allow for a higher spring preload but you can also achieve this by increasing the preload on your stock shocks and, as you do mention, with RT shocks on a GS/RS which have stiffer springs. Alternately you can simply purchase stiffer springs for any shocks. Purchasing very expensive high performance shocks solely to increase spring preload is not a good use of your mod money. In fact with a spring load so stiff as to reduce the actual shock from actuating, the value of performance shocks is even further reduced.
This has nothing to do with Faran's post but I'd also like to take this opportunity to point out that, unlike the anti-sway bar, increasing preload on your springs too much will adversely affect your ride comfort and possibly your safety. If you do decide to increase the preload on your springs you'll need to find a compromise that best suits your needs between reduced body roll, ride comfort, and safety. I recommend only increasing the spring preload until the ride comfort becomes unacceptable to you and then backing off. Don't try to eliminate all roll, this may actually be dangerous. A bit of body roll is perfectly normal and will not reduce your actual cornering performance much if at all. However most people do not like the sensation of body roll which may cause them to back off a bit on corners (which may actually be a good thing safety wise). A stiffer spring rate may also increase the possibility of lifting the inside wheel and significantly reducing the suspension systems ability to properly track the road especially when bumpy or when you hit a road hazard. Do you really want a spring rate so stiff as to reduce the ability of your suspension system to perform it's function just to lessen body roll a bit? If you do it makes little sense to purchase performance shocks because you're not giving them a chance to do their job.
So why purchase high performance shocks? Well if you're looking for significantly improved performance on rough or bumpy roads this can be one of your best investments. If you like to ride hard and fast on less than ideal roads, high performance shocks with their superior valving and heat dissipation will give you the best and safest ride possible. Buy performance shock for this reason, not just to increase spring preload which is a misuse of performance shocks imho. Ironically high performance shocks can also improve your safety in the corners but only if you let them do their jobs by not setting the spring rate so high so they can actually actuate enough to dampen shocks and sway which is their real function. If you set the spring rate so high that they can hardly move then you severely reduce their performance and your safety.
Bottom line: Know what your performance goals are before you spend your money. Know precisely what each component you purchase will do and how it does it. Finally know exactly how your modifications will affect the performance and safety of your ride.
