Ran across this inexpensive throttle lock. Looks like it might work for good temporary relief. At least it's cheap enough to try. http://www.2wheelride.com/throttle_pro.html
Printable View
Cant rest this one on MY brake lever !!!!!!!!!!!!!!!!!!!!!
:roflblack:
what size is are bars 78 or 2in im ording but dont know the size?:chat:
sorry no brake liver how crazy am i ?:gaah:
Another even less expensive lock... a 1 inch "O" ring ($.50) slipped in between the grip and switch. Just remember!!! :gaah:The throttle must be turned buth up and down! It will not go down under spring load due to the minor friction from the "O" ring.
Atleast you can let go of the throttle for a moment with your right hand if needed.
Did anyone notice how he put it on if you keep pulling that thing apart eventually it wont clap tight enough around the bar. jmo. :dontknow:
On my 2 wheelers, I used a wide rubber band between the grip and the metal piece. If you needed more friction on the throttle, you just made one or more additional wraps of the rubber band.:D
