Customer Accessory Circuit completely DEAD! Any thoughts?
Got a weird one here. I have had this bike since new and have the Signature Light installed via the front accessory circuit under the frunk tub. Has worked fine for 7yrs. Found it not working the other day and in testing, there is NO voltage in this circuit. Not just on the downstream side of the fuse but completely dead. No power at either side of the fuse.
My heated grips have also stopped working. ALL FUSES are good! I cannot find any material that is clear and concise on the relay(s) situation. Including the load shedding relay... I am going to see if there are any identical relays I can swap around for testing next but thought I would drop a line here for additional info....
Thoughts?
